Ir para o conteúdo principal
Air Hog Smash Bots Controller Motherboard Replacement
O que você precisa
  1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: passo 1, imagem 1 %32 Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: passo 1, imagem 2 %32
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Controller Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Controller Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Controller Motherboard Replacement: passo 4, imagem 1 %32 Air Hog Smash Bots Controller Motherboard Replacement: passo 4, imagem 2 %32
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Controller Motherboard Replacement: passo 5, imagem 1 %32 Air Hog Smash Bots Controller Motherboard Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: passo 6, imagem 1 %32 Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: passo 6, imagem 2 %32
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
Conclusão
Uma outra pessoa concluiu este guia.
Brittany Frecker
Membro desde: 02/08/16
542 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-1, Baechle Spring 2016 Membro de IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
Membros da 4
Autoria de 14 guias
Um comentário
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 162
