Ir para o conteúdo principal
Air Conditioning Thermostat Replacement
O que você precisa
  1. Air Conditioning Thermostat Replacement, Turn Off the Power: passo 1, imagem 1 %32 Air Conditioning Thermostat Replacement, Turn Off the Power: passo 1, imagem 2 %32 Air Conditioning Thermostat Replacement, Turn Off the Power: passo 1, imagem 3 %32
    • Before you begin, locate the circuit breaker switchboard for the housing unit.
    • Find the air conditioning breaker that’s typically labeled inside the breaker's panel cover.
    • Turn off the electrical breaker switch that supplies the air conditioning thermostat.
  2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: passo 2, imagem 1 %32 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: passo 2, imagem 2 %32 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: passo 2, imagem 3 %32
    • Separate the thermostat casing off of the wall plate. It should come off easily using your hands, but a pair of pliers can be used if it's being stubborn.
    • Take a picture using your phone's camera of the color-coded wiring, so it will be easier to re-attach the wiring to the new thermostat.
  3. Air Conditioning Thermostat Replacement: passo 3, imagem 1 %32 Air Conditioning Thermostat Replacement: passo 3, imagem 2 %32 Air Conditioning Thermostat Replacement: passo 3, imagem 3 %32
    • Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
    • Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
    • Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
  4. Air Conditioning Thermostat Replacement: passo 4, imagem 1 %32 Air Conditioning Thermostat Replacement: passo 4, imagem 2 %32 Air Conditioning Thermostat Replacement: passo 4, imagem 3 %32
    • Remove the old base plate of the thermostat.
    • Screw in the new base plate of the Thermostat using the Phillips or flathead screwdriver to screw in the Phillips #0 Plus screw drive.
    • Using the screwdriver; reconnect the color-coded wring based on the photo taken with your camera. (For example: Notice the yellow wiring)
  5. Air Conditioning Thermostat Replacement: passo 5, imagem 1 %32 Air Conditioning Thermostat Replacement: passo 5, imagem 2 %32
    • Use your fingers to wrap the copper around the terminal slots, Use your Flathead 3/32" 2.5 mm Screwdriver to tighten the terminal slots. (For example: Notice the yellow wiring)
    • Fasten the terminal slots using your Phillips Flathead 3/32" 2.5 mm Screwdriver.
  6. Air Conditioning Thermostat Replacement: passo 6, imagem 1 %32 Air Conditioning Thermostat Replacement: passo 6, imagem 2 %32
    • Place the new thermostat casing over the base plate.
    • Snap on the thermostat casing.
  7. Air Conditioning Thermostat Replacement: passo 7, imagem 1 %32 Air Conditioning Thermostat Replacement: passo 7, imagem 2 %32 Air Conditioning Thermostat Replacement: passo 7, imagem 3 %32
    • Locate the circuit breaker switchboard for the housing unit.
    • Locate the air conditioning electrical breaker switch.
    • Turn on the electrical breaker switch that the air conditioning thermostat supplies.
Conclusão
Uma outra pessoa concluiu este guia.
Genesis
Membro desde: 03/01/17
163 Reputação
Autoria de 1 guia
Equipe
Um comentário
ما هو السبب خروج علامت E3 في اسبلت westtin
السبلت ٣ طن عمودي
Hassan Alkanan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Duração total: 1,805
