Ir para o conteúdo principal
Air Blasters Tek Six Trigger Replacement
O que você precisa
  1. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: passo 1, imagem 1 %32 Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: passo 1, imagem 2 %32 Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: passo 1, imagem 3 %32
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: passo 2, imagem 1 %32 Air Blasters Tek Six Trigger Replacement, Remove screws in main body: passo 2, imagem 2 %32 Air Blasters Tek Six Trigger Replacement, Remove screws in main body: passo 2, imagem 3 %32
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Trigger Replacement, Take the main body apart: passo 3, imagem 1 %32 Air Blasters Tek Six Trigger Replacement, Take the main body apart: passo 3, imagem 2 %32 Air Blasters Tek Six Trigger Replacement, Take the main body apart: passo 3, imagem 3 %32
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Trigger Replacement, Remove the trigger: passo 4, imagem 1 %32 Air Blasters Tek Six Trigger Replacement, Remove the trigger: passo 4, imagem 2 %32 Air Blasters Tek Six Trigger Replacement, Remove the trigger: passo 4, imagem 3 %32
    • Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
Conclusão
Alfredo Antolinez
Membro desde: 09/22/14
347 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 3-1, Brown Fall 2014 Membro de USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 632
