Ir para o conteúdo principal
Air Blasters Tek Six Barrel Replacement
O que você precisa
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: passo 1, imagem 1 %32 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: passo 1, imagem 2 %32 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: passo 1, imagem 3 %32
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: passo 2, imagem 1 %32 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: passo 2, imagem 2 %32 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: passo 2, imagem 3 %32
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: passo 3, imagem 1 %32 Air Blasters Tek Six Barrel Replacement, Take the main body apart: passo 3, imagem 2 %32 Air Blasters Tek Six Barrel Replacement, Take the main body apart: passo 3, imagem 3 %32
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: passo 4, imagem 1 %32 Air Blasters Tek Six Barrel Replacement, Remove the trigger: passo 4, imagem 2 %32 Air Blasters Tek Six Barrel Replacement, Remove the trigger: passo 4, imagem 3 %32
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: passo 5, imagem 1 %32 Air Blasters Tek Six Barrel Replacement, Removing the barrel: passo 5, imagem 2 %32 Air Blasters Tek Six Barrel Replacement, Removing the barrel: passo 5, imagem 3 %32
    • Lift the barrel, pulling it out from under the black trigger catch
Conclusão
Joshua Taylor
Membro desde: 09/22/14
118 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-1, Brown Fall 2014 Membro de USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
Membros da 3
Autoria de 5 guias
Um comentário
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 399
