Ir para o conteúdo principal
Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement
O que você precisa
  1. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: passo 1, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: passo 1, imagem 2 %32 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: passo 1, imagem 3 %32
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 2, imagem 1 %32
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 3, imagem 1 %32
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 4, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 4, imagem 2 %32
    • Remove the sticky black dots.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 5, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 5, imagem 2 %32
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 6, imagem 1 %32
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 7, imagem 1 %32
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 8, imagem 1 %32
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 9, imagem 1 %32
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 10, imagem 1 %32
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: passo 11, imagem 1 %32
    • Replace the Lens Assembly board.
    • Be careful not to damage any of the pins. Pull the board linearly.
Conclusão
Uma outra pessoa concluiu este guia.
Gyozo Aba Hivatal
Membro desde: 01/21/15
561 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 6-4, Brown Winter 2015 Membro de USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 122
