Ir para o conteúdo principal
Aiptek Pocket DVII 1.3M LCD Display Screen Replacement
O que você precisa
  1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: passo 1, imagem 2 %32 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: passo 1, imagem 3 %32
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 2, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 2, imagem 2 %32
    • Remove the sticky black dots.
    • Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 3, imagem 1 %32
    • Using an opening tool, separate the cover from the screen.
    • The cover won't completely come off. This will happen in the next step.
    • Don't be afraid to use a little more force.
  4. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 4, imagem 1 %32
    • Using an opening tool remove the outside cover of the flip screen.
    • Move the cover towards the lens and then away from the screen.
  5. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 5, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 5, imagem 2 %32
    • With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
    • You only need to unplug the bottom cable in the picture.
  6. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 6, imagem 1 %32
    • Remove the two black screws from the circuit board.
  7. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 7, imagem 1 %32
    • With the opening tool, pop up the screen assembly.
    • The screen is glued to the black cover. Use more force if needed.
  8. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 8, imagem 1 %32
    • As in step 5, push up the brown locking mechanism of the remaining cable.
    • Unplug the picture cable.
  9. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 9, imagem 1 %32
    • Turn the circuit board over and with a soldering gun remove the two wires on each end.
    • Use a screwdriver to pull the loosened wire away.
  10. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: passo 10, imagem 1 %32
    • With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
Conclusão
Equipe
USF Tampa, Team 6-4, Brown Winter 2015 Membro de USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 351
