Ir para o conteúdo principal
Aiptek Pocket DVII 1.3M LCD Memory Ejecting Assembly Replacement
O que você precisa
  1. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: passo 1, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: passo 1, imagem 2 %32 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: passo 1, imagem 3 %32
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 2, imagem 1 %32
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 3, imagem 1 %32
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 4, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 4, imagem 2 %32
    • Remove the sticky black dot.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 5, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 5, imagem 2 %32
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 6, imagem 1 %32
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 7, imagem 1 %32
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 8, imagem 1 %32
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 9, imagem 1 %32
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 10, imagem 1 %32
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 11, imagem 1 %32
    • Remove the side cover.
    • Flip the device and locate the ejecting assembly.
  12. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 12, imagem 1 %32
    • Remove the grey button.
  13. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 13, imagem 1 %32
    • Push the metal arm the button was on all the way up.
  14. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 14, imagem 1 %32 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: passo 14, imagem 2 %32
    • Pop the main metal arm out of the other metal arm's socket.
    • Position the arm vertically like in the first picture. The arm should come off easily.
    • Replace the ejecting arm.
Conclusão
Uma outra pessoa concluiu este guia.
Gyozo Aba Hivatal
Membro desde: 01/21/15
561 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 6-4, Brown Winter 2015 Membro de USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 119
