Ir para o conteúdo principal
Aiptek DZO-V58N Lens Replacement
O que você precisa
  1. Aiptek DZO-V58N Lens Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
  2. Aiptek DZO-V58N Lens Replacement: passo 2, imagem 1 %32
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
  3. Aiptek DZO-V58N Lens Replacement, Lens Protector: passo 3, imagem 1 %32
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
  4. Aiptek DZO-V58N Lens Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
  5. Aiptek DZO-V58N Lens Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
  6. Aiptek DZO-V58N Lens Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to pry off the silver face plate.
  7. Aiptek DZO-V58N Lens Replacement: passo 7, imagem 1 %32 Aiptek DZO-V58N Lens Replacement: passo 7, imagem 2 %32 Aiptek DZO-V58N Lens Replacement: passo 7, imagem 3 %32
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  8. Aiptek DZO-V58N Lens Replacement: passo 8, imagem 1 %32
    • Pull off the side control panel.
  9. Aiptek DZO-V58N Lens Replacement: passo 9, imagem 1 %32 Aiptek DZO-V58N Lens Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
  10. Aiptek DZO-V58N Lens Replacement: passo 10, imagem 1 %32 Aiptek DZO-V58N Lens Replacement: passo 10, imagem 2 %32
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
  11. Aiptek DZO-V58N Lens Replacement, Lens: passo 11, imagem 1 %32 Aiptek DZO-V58N Lens Replacement, Lens: passo 11, imagem 2 %32 Aiptek DZO-V58N Lens Replacement, Lens: passo 11, imagem 3 %32
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
  12. Aiptek DZO-V58N Lens Replacement: passo 12, imagem 1 %32
    • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
  13. Aiptek DZO-V58N Lens Replacement: passo 13, imagem 1 %32
    • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
    • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
  14. Aiptek DZO-V58N Lens Replacement: passo 14, imagem 1 %32
    • Lift off the lens.
Conclusão
Zachary Yun
Membro desde: 04/03/12
7 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-5, Forte Spring 2012 Membro de Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 549
