Introdução
The image sensor is the component of the device responsible for sensing the light through the lens and converting it into an electrical signal. The sensor captures a new image 30 times per second in order to create a video. The sensor is a very fragile and sensitive component. Take caution when handling the new image sensor to be installed in the device. Use this guide to replace the image sensor.
O que você precisa
Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
Slide the battery compartment cover down off of the camera body.
Remove the lanyard by pulling the grey lace through the black string loop.
Pull black string loop through the silver bracket.
Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
Lift off the lens protector housing.
Pull apart the two halves of the camera body.
Use the #00 Phillips Screwdriver to unscrew the 3 circuit board screws.
Slightly separate circuit board from plastic case by lifting the circuit board straight out.
