Ir para o conteúdo principal
Afterglow Wireless PS3 Controller Motherboard Replacement
O que você precisa
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: passo 2, imagem 1 %32
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 3, imagem 1 %32 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 3, imagem 2 %32
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 4, imagem 1 %32 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 4, imagem 2 %32
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 5, imagem 1 %32 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 5, imagem 2 %32
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 6, imagem 1 %32 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 6, imagem 2 %32
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
Conclusão
Natalie Cox
Membro desde: 02/17/17
207 Reputação
2 Guias de autoria
Equipe
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membros
14 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 839
