Ir para o conteúdo principal
Afterglow Wireless PS3 Controller Button Replacement
O que você precisa
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: passo 1, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: passo 1, imagem 2 %32
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Pergunte ao FixBot
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: passo 2, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement, Button: passo 2, imagem 2 %32
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Pergunte ao FixBot
  3. Afterglow Wireless PS3 Controller Button Replacement: passo 3, imagem 1 %32
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    Pergunte ao FixBot
  4. Afterglow Wireless PS3 Controller Button Replacement: passo 4, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement: passo 4, imagem 2 %32
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
    Pergunte ao FixBot
  5. Afterglow Wireless PS3 Controller Button Replacement: passo 5, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement: passo 5, imagem 2 %32
    • Pull both vibration motors straight up from their holding place.
    Pergunte ao FixBot
  6. Afterglow Wireless PS3 Controller Button Replacement: passo 6, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement: passo 6, imagem 2 %32
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
    Pergunte ao FixBot
  7. Afterglow Wireless PS3 Controller Button Replacement: passo 7, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement: passo 7, imagem 2 %32
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
    Pergunte ao FixBot
  8. Afterglow Wireless PS3 Controller Button Replacement: passo 8, imagem 1 %32 Afterglow Wireless PS3 Controller Button Replacement: passo 8, imagem 2 %32 Afterglow Wireless PS3 Controller Button Replacement: passo 8, imagem 3 %32
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
    Pergunte ao FixBot
Conclusão
5 outras pessoas executaram este guia.
Aj Coello
Membro desde: 02/17/17
1.164 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 92
Ao todo: 2,537
