Ir para o conteúdo principal
Afridev Pump Rod Replacement
O que você precisa
  1. Afridev Pump Rod Replacement, Head: passo 1, imagem 1 %32 Afridev Pump Rod Replacement, Head: passo 1, imagem 2 %32
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Pump Rod Replacement: passo 2, imagem 1 %32 Afridev Pump Rod Replacement: passo 2, imagem 2 %32 Afridev Pump Rod Replacement: passo 2, imagem 3 %32
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Pump Rod Replacement: passo 3, imagem 1 %32 Afridev Pump Rod Replacement: passo 3, imagem 2 %32
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Pump Rod Replacement, Axle and Handle: passo 4, imagem 1 %32 Afridev Pump Rod Replacement, Axle and Handle: passo 4, imagem 2 %32 Afridev Pump Rod Replacement, Axle and Handle: passo 4, imagem 3 %32
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Pump Rod Replacement: passo 5, imagem 1 %32 Afridev Pump Rod Replacement: passo 5, imagem 2 %32
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Pump Rod Replacement: passo 6, imagem 1 %32 Afridev Pump Rod Replacement: passo 6, imagem 2 %32 Afridev Pump Rod Replacement: passo 6, imagem 3 %32
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Pump Rod Replacement: passo 7, imagem 1 %32 Afridev Pump Rod Replacement: passo 7, imagem 2 %32
    • Lift the handle to a horizontal position.
  8. Afridev Pump Rod Replacement: passo 8, imagem 1 %32 Afridev Pump Rod Replacement: passo 8, imagem 2 %32 Afridev Pump Rod Replacement: passo 8, imagem 3 %32
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Pump Rod Replacement: passo 9, imagem 1 %32 Afridev Pump Rod Replacement: passo 9, imagem 2 %32 Afridev Pump Rod Replacement: passo 9, imagem 3 %32
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Pump Rod Replacement: passo 10, imagem 1 %32 Afridev Pump Rod Replacement: passo 10, imagem 2 %32
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Pump Rod Replacement, Pump Rod: passo 11, imagem 1 %32 Afridev Pump Rod Replacement, Pump Rod: passo 11, imagem 2 %32
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Pump Rod Replacement: passo 12, imagem 1 %32 Afridev Pump Rod Replacement: passo 12, imagem 2 %32
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Pump Rod Replacement: passo 13, imagem 1 %32 Afridev Pump Rod Replacement: passo 13, imagem 2 %32 Afridev Pump Rod Replacement: passo 13, imagem 3 %32
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Pump Rod Replacement: passo 14, imagem 1 %32 Afridev Pump Rod Replacement: passo 14, imagem 2 %32 Afridev Pump Rod Replacement: passo 14, imagem 3 %32
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
Conclusão
Uma outra pessoa concluiu este guia.
Jake Devincenzi
Membro desde: 04/18/11
118.791 Reputação
Autoria de 57 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 468
