Ir para o conteúdo principal
Adjusting the alarm glass breakage microphone sensitivity
O que você precisa
  1. Adjusting the alarm glass breakage microphone sensitivity: passo 2, imagem 1 %32
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Adjusting the alarm glass breakage microphone sensitivity: passo 3, imagem 1 %32
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  3. Adjusting the alarm glass breakage microphone sensitivity: passo 4, imagem 1 %32
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  4. Adjusting the alarm glass breakage microphone sensitivity: passo 5, imagem 1 %32
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
Conclusão
3 outras pessoas executaram este guia.
mpeeples
Membro desde: 04/04/10
184 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 2,551
