Ir para o conteúdo principal
Adjusting Right/Left Speaker Balance
  1. Adjusting Right/Left Speaker Balance, Adjusting Right/Left Speaker Balance: passo 1, imagem 1 %32
    • The balance knob is the rightmost knob on the front panel.
  2. Adjusting Right/Left Speaker Balance: passo 2, imagem 1 %32 Adjusting Right/Left Speaker Balance: passo 2, imagem 2 %32
    • Turning the balance knob to the right increases the sound played by the right speaker.
    • Turning the knob left will increase the sound played by the left speaker.
  3. Adjusting Right/Left Speaker Balance: passo 3, imagem 1 %32 Adjusting Right/Left Speaker Balance: passo 3, imagem 2 %32
    • Turning the knob all the way to the right will make the right speaker play all the sound.
    • Turning the knob all the way to the left will make the left speaker play all the sound.
  4. Adjusting Right/Left Speaker Balance: passo 4, imagem 1 %32
    • The default position is center, which should play the sound equally by both speakers.
    • If this position does not play the sound equally by both speakers, experiment with different knob positions until the speakers play the sound equally.
Linha de Chegada
Jan Vazquez
Membro desde: 04/09/10
254 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 27-92, Amido Spring 2010 Membro de Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Membros
Autoria de 10 guias
1Comentário do guia
Finally, I can die in peace
john goor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 66
Ao todo: 6,143
