Ir para o conteúdo principal
Adjusting Nishiki Aero II Seat
O que você precisa
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: passo 1, imagem 1 %32 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: passo 1, imagem 2 %32 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: passo 1, imagem 3 %32
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: passo 2, imagem 1 %32 Adjusting Nishiki Aero II Seat: passo 2, imagem 2 %32
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: passo 3, imagem 1 %32
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Conclusão
Tobias Elder
Membro desde: 04/25/13
113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-53, Johann Spring 2013 Membro de Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Duração total: 2,859
