Ir para o conteúdo principal
Adjusting Nishiki Aero II Front Derailleur
O que você precisa
  1. Adjusting Nishiki Aero II Front Derailleur, Adjusting Nishiki Aero II Front Derailleur: passo 1, imagem 1 %32
    • Shift the bike's rear derailleur onto the innermost gear.
  2. Adjusting Nishiki Aero II Front Derailleur: passo 2, imagem 1 %32
    • Shift the front derailleur as far inward as it can go.
    • If the chain falls off, tighten the outside limit screw on top of the derailleur.
    • If the chain can't shift to the lower gear, loosen the outside limit screw on top of the derailleur.
    • Yes, the outer limit screw adjusts the inner derailleur limit.
  3. Adjusting Nishiki Aero II Front Derailleur: passo 3, imagem 1 %32
    • Next, shift the rear derailleur onto the outermost gear.
  4. Adjusting Nishiki Aero II Front Derailleur: passo 4, imagem 1 %32
    • Shift the front derailleur as far outwards as you can.
    • If the derailleur shifts the chain off the gear, tighten the inner limit screw on top of the front derailleur.
    • If the derailleur is unable to shift onto the outer gear, loosen the inner limit screw on top of the front derailleur.
    • Just like last time, the inner limit screw adjusts the outer limit of the derailleur.
Conclusão
Now, your bike shouldn't have any more problems with the chain falling off.
Tobias Elder
Membro desde: 04/25/13
113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-53, Johann Spring 2013 Membro de Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,854
