Pular para o conteúdo principal
Introdução
The magnet is located in the water reservoir of the brewer and functions as a water level sensor that detects when the coffee maker needs to be refilled with water.
  1. Before starting the repair, make sure that the device is unplugged and the water reservoir is empty.
    • Before starting the repair, make sure that the device is unplugged and the water reservoir is empty.
    • Detach the water reservoir from the brewer by lifting the reservoir vertically from the device.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. The magnet is located in the bottom of the reservoir. Remove the grey lid from the top of the reservoir.
    • The magnet is located in the bottom of the reservoir.
    • Remove the grey lid from the top of the reservoir.
    • Insert your hand and manually realign the magnet to where it slides freely in its enclosed area.
Conclusão
Uma outra pessoa concluiu este guia.
Alexander Vo
Membro desde: 11-01-2013
91 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 20-2, Maness Winter 2013 Membro de Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 97
Todo: 10,875
