Ir para o conteúdo principal
Adjusting Contrast on TI-Nspire Calculator
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: passo 1, imagem 1 %32 Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: passo 1, imagem 2 %32
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. Adjusting Contrast on TI-Nspire Calculator: passo 2, imagem 1 %32 Adjusting Contrast on TI-Nspire Calculator: passo 2, imagem 2 %32 Adjusting Contrast on TI-Nspire Calculator: passo 2, imagem 3 %32
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
Conclusão
Now you should have the image contrast set to your preferences.
Uma outra pessoa concluiu este guia.
Alan Wong
Membro desde: 09/26/12
63 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-52, Forte Fall 2012 Membro de Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 21
Duração total: 5,904
