Ir para o conteúdo principal
Adjust the Action (String Height) on Ibanez SR405QM
O que você precisa
  1. Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: passo 1, imagem 1 %32 Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: passo 1, imagem 2 %32
    • Pay attention to the distance between both the fretboard and pickups.
    • Test the strings by plucking and take note of which ones are difficult to play or are producing an unpleasant metallic sound.
  2. Adjust the Action (String Height) on Ibanez SR405QM: passo 2, imagem 1 %32 Adjust the Action (String Height) on Ibanez SR405QM: passo 2, imagem 2 %32
    • Using a 2 mm Allen Key turn the corresponding string's screw clockwise to raise the string and counterclockwise to lower the string.
    • The screw is located on the bridge of the guitar next to its corresponding string.
    • While modifying a strings height try plucking the string and listening to the sound produced until at desired sound.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Chris Pittner
Membro desde: 01/11/13
220 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-18, Forte Winter 2013 Membro de Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 34
Últimos 30 dias: 126
Duração total: 6,077
