Ir para o conteúdo principal
Adjust Nintendo DS picture
O que você precisa
  1. Adjust Nintendo DS picture, Adjust Nintendo DS picture: passo 1, imagem 1 %32
    • First check if the DS has image flickering. It is best to do this with a still image, such as the boot screen.
    • But make sure the backlight is on.
  2. Adjust Nintendo DS picture: passo 2, imagem 1 %32 Adjust Nintendo DS picture: passo 2, imagem 2 %32
    • Loosen the Phillips #00 screw on the battery compartment
    • remove the cover
  3. Adjust Nintendo DS picture: passo 3, imagem 1 %32
    • in these two openings are potentiometers responsible for the image.
    • Above is for the Upper LCD
    • Below for the Lower LCD
    • It's best to check both of them out.
    • Now you can turn on the console and make sure the backlight is on.
  4. Adjust Nintendo DS picture: passo 5, imagem 1 %32
    • Then you can turn left and right with the Phillips #00 screwdriver to adjust the picture.
    • But always take a look at the screens to get a good picture
    • It is also important not to turn too fast and not too far. The trick is to do this slowly and gently.
  5. Adjust Nintendo DS picture: passo 6, imagem 1 %32
    • If everything fits and the LCD screens display the picture well, you can close the battery door.
Conclusão
Close the battery compartment with the battery inside
Um agradecimento especial a esses tradutores:
de en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Patrick Stork
Membro desde: 08/05/18
401 Reputação
Autoria de 1 guia
2 comentários
BOA NOITE
Gostaria de saber se as telas superior e inferior sao iguais??
Andre Miranda - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 38
Últimos 30 dias: 131
Ao todo: 2,952
