Ir para o conteúdo principal
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
O que você precisa
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 1, imagem 1 %32 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 1, imagem 2 %32
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 2, imagem 1 %32 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 2, imagem 2 %32 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 2, imagem 3 %32
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 3, imagem 1 %32 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 3, imagem 2 %32 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: passo 3, imagem 3 %32
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Linha de Chegada
Uma outra pessoa concluiu este guia.
aaron thielk
Membro desde: 10/10/10
1.882 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-13, Maness Fall 2010 Membro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
Membros da 4
Autoria de 17 guias
Um comentário
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 25
Duração total: 9,239
