Ir para o conteúdo principal
AcuRite 02032 Wind Vane Replacement
O que você precisa
  1. AcuRite 02032 Wind Vane Replacement, Battery: passo 1, imagem 1 %32 AcuRite 02032 Wind Vane Replacement, Battery: passo 1, imagem 2 %32 AcuRite 02032 Wind Vane Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery compartment lid by lifting upward.
  2. AcuRite 02032 Wind Vane Replacement: passo 2, imagem 1 %32
    • Pull the ribbon to eject the 2 X AA alkaline batteries.
  3. AcuRite 02032 Wind Vane Replacement: passo 3, imagem 1 %32 AcuRite 02032 Wind Vane Replacement: passo 3, imagem 2 %32 AcuRite 02032 Wind Vane Replacement: passo 3, imagem 3 %32
    • Once the batteries are removed, it is safe to proceed.
  4. AcuRite 02032 Wind Vane Replacement, Wind Vane: passo 4, imagem 1 %32 AcuRite 02032 Wind Vane Replacement, Wind Vane: passo 4, imagem 2 %32 AcuRite 02032 Wind Vane Replacement, Wind Vane: passo 4, imagem 3 %32
    • Firmly grasp the windvane with one hand and the rest of the device with the other hand.
    • Pull straight outwards. A quick yank with force should be enough to remove the propeller.
  5. AcuRite 02032 Wind Vane Replacement: passo 5, imagem 1 %32 AcuRite 02032 Wind Vane Replacement: passo 5, imagem 2 %32
    • To reattach the replacement wind vane, line up the small notch in the socket where the pieces fit together then carefully push the parts together.
Conclusão
Uma outra pessoa concluiu este guia.
Ben Kegel
Membro desde: 09/15/16
350 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-4, Bruce Fall 2016 Membro de CSU Fullerton, Team 1-4, Bruce Fall 2016
CSUF-BRUCE-F16S1G4
Membros da 5
Autoria de 7 guias
Um comentário
I had a herd of elk come through my yard (judging by the large hoofprints). Apparently one of them got tangled up in the guy rope for my antenna mast and the mast came tumbling to the ground. At the top of the mast about 35 feet up was my Acurite 5-in-1 Sensor, which also fell to the ground and broke the wind vane. The replacement vane cost 5 dollars. Pull off the broken one, push on the new one, done in a few seconds.
Acurite’s instructions about replacing the wind vane are as follows:
“The wind vane is pressed onto the shaft, pull firmly to remove it. To attach the wind vane, align the wind vane with the flat on the shaft and press into place.”
They don’t say anything about removing the batteries.
Hal Jordan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,374
