Ir para o conteúdo principal
Acer Travelmate 220 RAM Replacement
O que você precisa
  1. Acer Travelmate 220 RAM Replacement, RAM Chip: passo 1, imagem 1 %32
    • Place the computer with the bottom facing up.
  2. Acer Travelmate 220 RAM Replacement: passo 2, imagem 1 %32 Acer Travelmate 220 RAM Replacement: passo 2, imagem 2 %32 Acer Travelmate 220 RAM Replacement: passo 2, imagem 3 %32
    • Locate the larger cover panel in the upper left hand corner of the computer.
    • Locate the Phillips screw holding the large cover panel in place.
  3. Acer Travelmate 220 RAM Replacement: passo 3, imagem 1 %32 Acer Travelmate 220 RAM Replacement: passo 3, imagem 2 %32
    • Remove the located screw with the Phillips #00 screwdriver.
  4. Acer Travelmate 220 RAM Replacement: passo 4, imagem 1 %32
    • Slide the large cover panel to the right, until you hear a click.
  5. Acer Travelmate 220 RAM Replacement: passo 5, imagem 1 %32 Acer Travelmate 220 RAM Replacement: passo 5, imagem 2 %32
    • Place the plastic opening tool in the gap created to the left of the large cover panel.
    • Pry the cover panel up and remove it from the computer.
  6. Acer Travelmate 220 RAM Replacement: passo 6, imagem 1 %32 Acer Travelmate 220 RAM Replacement: passo 6, imagem 2 %32
    • Locate the white plastic levers on each side of the two RAM chips.
  7. Acer Travelmate 220 RAM Replacement: passo 7, imagem 1 %32 Acer Travelmate 220 RAM Replacement: passo 7, imagem 2 %32 Acer Travelmate 220 RAM Replacement: passo 7, imagem 3 %32
    • Locate the first RAM chip.
    • Push the plastic levers away from the first RAM chip.
  8. Acer Travelmate 220 RAM Replacement: passo 8, imagem 1 %32 Acer Travelmate 220 RAM Replacement: passo 8, imagem 2 %32 Acer Travelmate 220 RAM Replacement: passo 8, imagem 3 %32
    • Lift the RAM chip from the compartment.
    • Repeat steps 7 and 8 to replace the second RAM chip.
Conclusão
Kevin A
Membro desde: 10/04/11
55 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team 5-5, Zhou Fall 2011 Membro de UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 3,393
