Ir para o conteúdo principal
Acer TravelMate TMB115-M-C99B Screen Replacement
O que você precisa
  1. Acer TravelMate TMB115-M-C99B Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Screen Replacement: passo 2, imagem 1 %32 Acer TravelMate TMB115-M-C99B Screen Replacement: passo 2, imagem 2 %32 Acer TravelMate TMB115-M-C99B Screen Replacement: passo 2, imagem 3 %32
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Screen Replacement: passo 3, imagem 1 %32
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Screen Replacement: passo 4, imagem 1 %32 Acer TravelMate TMB115-M-C99B Screen Replacement: passo 4, imagem 2 %32
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Screen Replacement, Screen: passo 5, imagem 1 %32 Acer TravelMate TMB115-M-C99B Screen Replacement, Screen: passo 5, imagem 2 %32
    • Use the metal spudger to pry open the front plastic cover of the screen.
  6. Acer TravelMate TMB115-M-C99B Screen Replacement: passo 6, imagem 1 %32 Acer TravelMate TMB115-M-C99B Screen Replacement: passo 6, imagem 2 %32 Acer TravelMate TMB115-M-C99B Screen Replacement: passo 6, imagem 3 %32
    • Take off the front plastic cover then remove four 6mm Phillips screws using the #0 screwdriver.
  7. Acer TravelMate TMB115-M-C99B Screen Replacement: passo 7, imagem 1 %32 Acer TravelMate TMB115-M-C99B Screen Replacement: passo 7, imagem 2 %32
    • Flip the screen and disconnect the port.
  8. Acer TravelMate TMB115-M-C99B Screen Replacement: passo 8, imagem 1 %32
    • Remove the screen.
Conclusão
Melissa Martinez
Membro desde: 01/24/19
279 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S1-G5, White Winter 2019 Membro de Cal Poly, Team S1-G5, White Winter 2019
CPSU-WHITE-W19S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 440
