Ir para o conteúdo principal
Acer TravelMate TMB115-M-C99B Motherboard Replacement
O que você precisa
  1. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 2, imagem 1 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 2, imagem 2 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 4, imagem 1 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 4, imagem 2 %32
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: passo 5, imagem 1 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: passo 5, imagem 2 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: passo 5, imagem 3 %32
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 7, imagem 1 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 7, imagem 2 %32
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 9, imagem 1 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 10, imagem 1 %32 Acer TravelMate TMB115-M-C99B Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Melissa Martinez
Membro desde: 01/24/19
279 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S1-G5, White Winter 2019 Membro de Cal Poly, Team S1-G5, White Winter 2019
CPSU-WHITE-W19S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 534
