Ir para o conteúdo principal
Acer TravelMate P653-V-6882 DC Input Replacement
O que você precisa
  1. Acer TravelMate P653-V-6882 DC Input Replacement, Battery Pack: passo 1, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement, Battery Pack: passo 1, imagem 2 %32
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 DC Input Replacement: passo 2, imagem 1 %32
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 DC Input Replacement: passo 3, imagem 1 %32
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 DC Input Replacement, ODD Module: passo 4, imagem 1 %32
    • Slide the ODD module latch down.
    • The ODD module will pop out.
  5. Acer TravelMate P653-V-6882 DC Input Replacement: passo 5, imagem 1 %32
    • Remove the ODD module.
  6. Acer TravelMate P653-V-6882 DC Input Replacement, Base Door: passo 6, imagem 1 %32
    • Remove the five 7mm Phillips #1 screws.
  7. Acer TravelMate P653-V-6882 DC Input Replacement: passo 7, imagem 1 %32
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  8. Acer TravelMate P653-V-6882 DC Input Replacement: passo 8, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 8, imagem 2 %32
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  9. Acer TravelMate P653-V-6882 DC Input Replacement, Keyboard: passo 9, imagem 1 %32
    • Remove the two 7mm Phillips #1 screws.
  10. Acer TravelMate P653-V-6882 DC Input Replacement: passo 10, imagem 1 %32
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  11. Acer TravelMate P653-V-6882 DC Input Replacement: passo 11, imagem 1 %32
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  12. Acer TravelMate P653-V-6882 DC Input Replacement: passo 12, imagem 1 %32
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
  13. Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: passo 13, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: passo 13, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement, Mainboard: passo 13, imagem 3 %32
    • Turn the computer over, open the LCD panel, and find the smart card cable connector.
    • Open the smart card cable connector latch.
    • Disconnect the cable.
  14. Acer TravelMate P653-V-6882 DC Input Replacement: passo 14, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 14, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 14, imagem 3 %32
    • Find the power button launch board cable connector.
    • Open the power button launch board cable connector latch.
  15. Acer TravelMate P653-V-6882 DC Input Replacement: passo 15, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 15, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 15, imagem 3 %32
    • Find the touchpad and fingerprint board cable connector.
    • Open the touchpad and fingerprint board cable connector’s latches.
    • Disconnect the cables.
  16. Acer TravelMate P653-V-6882 DC Input Replacement: passo 16, imagem 1 %32
    • Using the #1 Phillips screwdriver, remove the two screws.
  17. Acer TravelMate P653-V-6882 DC Input Replacement: passo 17, imagem 1 %32
    • Flip the laptop over so that the underside is facing up.
    • Remove the twelve 7mm Phillips #1 screws.
    • Remove the five 3mm Phillips #1 screws.
    • Disconnect the cables connecting to the WLAN module.
  18. Acer TravelMate P653-V-6882 DC Input Replacement: passo 18, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 18, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 18, imagem 3 %32
    • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
    • Insert the opening tool into each gap to separate the one from the other.
    • Once the upper cover is separated, lift it from the lower case.
    • Be careful not to damage the upper and lower case while removing.
  19. Acer TravelMate P653-V-6882 DC Input Replacement: passo 19, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 19, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 19, imagem 3 %32
    • Detach the transparent tape securing the LCD cable.
    • Disconnect the LCD cable from the mainboard.
    • Be careful not to damage the LCD cable connector.
  20. Acer TravelMate P653-V-6882 DC Input Replacement: passo 20, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 20, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 20, imagem 3 %32
    • Detach the black tape covering the microphone cable.
    • Disconnect the microphone cable from the mainboard.
  21. Acer TravelMate P653-V-6882 DC Input Replacement: passo 21, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 21, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 21, imagem 3 %32
    • Open the USB board cable's connector latches.
    • Be careful not to damage the connectors.
  22. Acer TravelMate P653-V-6882 DC Input Replacement: passo 22, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 22, imagem 2 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 22, imagem 3 %32
    • Disconnect the left speaker cable from the mainboard.
  23. Acer TravelMate P653-V-6882 DC Input Replacement: passo 23, imagem 1 %32
    • Remove the one 7mm Phillips #1 screw.
  24. Acer TravelMate P653-V-6882 DC Input Replacement: passo 24, imagem 1 %32 Acer TravelMate P653-V-6882 DC Input Replacement: passo 24, imagem 2 %32
    • Lift the mainboard at an angle and gently turn it on its side.
    • Disconnect the LAN cable from the mainboard.
  25. Acer TravelMate P653-V-6882 DC Input Replacement, DC Input: passo 25, imagem 1 %32
    • Disconnect the DC input cable from the mainboard.
Conclusão
Daniel Popovic
Membro desde: 01/13/20
985 Reputação
Autoria de 7 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 245
