Ir para o conteúdo principal
Acer TravelMate P653-V-6882 Base Door Replacement
O que você precisa
  1. Acer TravelMate P653-V-6882 Base Door Replacement, Battery Pack: passo 1, imagem 1 %32 Acer TravelMate P653-V-6882 Base Door Replacement, Battery Pack: passo 1, imagem 2 %32
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 Base Door Replacement: passo 2, imagem 1 %32
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 Base Door Replacement: passo 3, imagem 1 %32
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 Base Door Replacement, Base Door: passo 4, imagem 1 %32
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 Base Door Replacement: passo 5, imagem 1 %32
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 Base Door Replacement: passo 6, imagem 1 %32 Acer TravelMate P653-V-6882 Base Door Replacement: passo 6, imagem 2 %32
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
Conclusão
Daniel Popovic
Membro desde: 01/13/20
985 Reputação
Autoria de 7 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 329
