Ir para o conteúdo principal
Acer Spin SP513-52N Charging Port Replacement
O que você precisa
  1. Acer Spin SP513-52N Charging Port Replacement, Charging Port: passo 1, imagem 1 %32
    • Power off your laptop before beginning disassembly and disconnect the device from the charger.
    • Use a Phillips #0 screwdriver to remove twelve 6.0 mm screws from the back panel.
  2. Acer Spin SP513-52N Charging Port Replacement: passo 2, imagem 1 %32 Acer Spin SP513-52N Charging Port Replacement: passo 2, imagem 2 %32
    • Use an opening tool in the seam of back case and slide it around the perimeter to release the clips securing it to the top case.
    • Remove the back case to reveal the internals of the laptop.
  3. Acer Spin SP513-52N Charging Port Replacement: passo 3, imagem 1 %32 Acer Spin SP513-52N Charging Port Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Before replacing the charging port, unplug the internal battery from the motherboard.
    • Unplug the broken charging port from the motherboard with tweezers.
  4. Acer Spin SP513-52N Charging Port Replacement: passo 4, imagem 1 %32
  5. Acer Spin SP513-52N Charging Port Replacement: passo 5, imagem 1 %32 Acer Spin SP513-52N Charging Port Replacement: passo 5, imagem 2 %32
    • Use tweezers to insert the new charging port securely.
  6. Acer Spin SP513-52N Charging Port Replacement: passo 6, imagem 1 %32
    • Place the back case onto the laptop and press down around the edges of the perimeter.
    • You should hear the clips snap together.
  7. Acer Spin SP513-52N Charging Port Replacement: passo 7, imagem 1 %32
    • Use a Phillips #0 screwdriver to fasten the twelve 6.0 mm screws back into place.
Conclusão
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Sara Al-Shumari
Membro desde: 01/10/21
145 Reputação
Autoria de 1 guia
Equipe
York University, Team B-4, Allen Fall 2022 Membro de York University, Team B-4, Allen Fall 2022
YORK-ALLEN-F22SBG4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 35
Duração total: 1,204
