Ir para o conteúdo principal
Acer Spin 7 SP714-51 Trackpad Replacement
O que você precisa
  1. Acer Spin 7 SP714-51 Trackpad Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Trackpad Replacement: passo 2, imagem 1 %32
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
  3. Acer Spin 7 SP714-51 Trackpad Replacement: passo 3, imagem 1 %32 Acer Spin 7 SP714-51 Trackpad Replacement: passo 3, imagem 2 %32
    • Remove the battery connector cable from the motherboard.
    • This will cut power to the laptop, reducing the likelihood of damage and injury.
    • Ensure that you are pulling the connector straight back, if you pull up at all you may damage the battery connector on the motherboard.
  4. Acer Spin 7 SP714-51 Trackpad Replacement: passo 4, imagem 1 %32 Acer Spin 7 SP714-51 Trackpad Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the last two 3mm long fasteners at the edge of the laptop body, and carefully remove the battery.
    • Place the new battery in the battery slot
    • Do not bend or puncture the battery.
  5. Acer Spin 7 SP714-51 Trackpad Replacement, Trackpad: passo 5, imagem 1 %32
    • Use your fingernail or another small pry tool to gently pry up the black locking tab on the ribbon cable connector, then slide the ribbon cable out gently holding the blue tab attached to the cable.
    • Take great care not to damage the ribbon cable or the cable connector.
  6. Acer Spin 7 SP714-51 Trackpad Replacement: passo 6, imagem 1 %32 Acer Spin 7 SP714-51 Trackpad Replacement: passo 6, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the five 2mm screws from the back of the trackpad, then carefully remove the trackpad and set it aside.
Conclusão
Zach Desrosiers
Membro desde: 03/22/22
565 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-3, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 185
