Ir para o conteúdo principal
Acer Spin 7 SP714-51 Keyboard Replacement
O que você precisa
  1. Acer Spin 7 SP714-51 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Keyboard Replacement: passo 2, imagem 1 %32
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
  3. Acer Spin 7 SP714-51 Keyboard Replacement: passo 3, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the battery connector cable from the motherboard.
    • This will cut power to the laptop, reducing the likelihood of damage and injury.
    • Ensure that you are pulling the connector straight back, if you pull up at all you may damage the battery connector on the motherboard.
  4. Acer Spin 7 SP714-51 Keyboard Replacement: passo 4, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the last two 3mm long fasteners at the edge of the laptop body, and carefully remove the battery.
    • Place the new battery in the battery slot
    • Do not bend or puncture the battery.
  5. Acer Spin 7 SP714-51 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32 Acer Spin 7 SP714-51 Keyboard Replacement, Keyboard: passo 5, imagem 3 %32
    • Disconnect the white and black antennae from the Wi-Fi card, located on the left side of the laptop. The antennae should snap off upwards easily with a pry tool.
    • Unscrew the retaining screw from the Wi-Fi card and unslot the card to remove it from the laptop.
  6. Acer Spin 7 SP714-51 Keyboard Replacement: passo 6, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 6, imagem 2 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 6, imagem 3 %32
    • Lift the tab on the ribbon connector connecting the motherboard to the power switchboard and slide out the connector.
    • Remove the 2 screws holding the switchboard in place and remove the switch panel.
  7. Acer Spin 7 SP714-51 Keyboard Replacement: passo 7, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 7, imagem 2 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 7, imagem 3 %32
    • Flip up the tab on the keyboard connector and disconnect the ribbon cable from the motherboard.
  8. Acer Spin 7 SP714-51 Keyboard Replacement: passo 8, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 8, imagem 2 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 8, imagem 3 %32
    • Remove the display connector by lifting the tape and pulling the connector straight back.
    • Remove the trackpad ribbon cable.
    • Remove the speaker connectors, lifting the tape and pulling straight back from the connector.
  9. Acer Spin 7 SP714-51 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the touchscreen connector after peeling up the adhesive tape holding it in place.
    • Make sure to pull straight back to avoid damaging the connector.
  10. Acer Spin 7 SP714-51 Keyboard Replacement: passo 10, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 10, imagem 2 %32
    • On the upper left side of the back panel is a protective shield for the USB-C panel. Remove the two 3mm screws holding the panel in place using the PH0 Phillips head screwdriver.
    • Gently pull the panel away being careful not to damage anything.
  11. Acer Spin 7 SP714-51 Keyboard Replacement: passo 11, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 11, imagem 2 %32
    • Unscrew the silver 3mm long screws holding the motherboard using the PH0 bit and remove them carefully to avoid breaking them.
    • This will allow the user to get to the keyboard without any other parts in the way making it easier to work with.
  12. Acer Spin 7 SP714-51 Keyboard Replacement: passo 12, imagem 1 %32
    • Partially covering the keyboard is a heatsink, grab the two edges as seen in the photo.
    • Carefully pull away the heatsink to gain access to the keyboard.
  13. Acer Spin 7 SP714-51 Keyboard Replacement: passo 13, imagem 1 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 13, imagem 2 %32 Acer Spin 7 SP714-51 Keyboard Replacement: passo 13, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the 2 mm screws that secure the keyboard in place, and carefully remove the keyboard to avoid breaking it.
Conclusão
Zach Desrosiers
Membro desde: 03/22/22
565 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-3, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 471
