Ir para o conteúdo principal
Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement
O que você precisa
  1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: passo 1, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: passo 1, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 2, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 2, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 2, imagem 3 %32
    • Remove the piece of black tape that covers the battery.
  3. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 3, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 3, imagem 2 %32
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  4. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 4, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 4, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 4, imagem 3 %32
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  5. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 5, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 5, imagem 2 %32
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  6. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: passo 6, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: passo 6, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: passo 6, imagem 3 %32
    • Using tweezers, remove the sticker that covers the connection between the wireless card and motherboard.
  7. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 7, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 7, imagem 2 %32
    • Remove the 6.5 mm screw that secures the wireless card using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 8, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 8, imagem 2 %32
    • Gently pull the wireless card away from the motherboard.
  9. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 9, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 9, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 9, imagem 3 %32
    • Using your fingers, carefully pull the white wire upwards, removing it from the terminal of the wireless card.
  10. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 10, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 10, imagem 2 %32
    • Repeat the previous step but this time for the black wire.
  11. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 11, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: passo 11, imagem 2 %32
    • Remove the wireless (WiFi) card from the laptop.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 44
Ao todo: 1,815
