Ir para o conteúdo principal
Acer Spin 5 SP515-51GN-807G Hard Drive Replacement
O que você precisa
  1. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 2, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 2, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 3, imagem 1 %32
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement, Battery: passo 4, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement, Battery: passo 4, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 5, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 5, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 6, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 6, imagem 2 %32
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 7, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 7, imagem 2 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 7, imagem 3 %32
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 8, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement: passo 8, imagem 2 %32
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  9. Acer Spin 5 SP515-51GN-807G Hard Drive Replacement, Hard Drive: passo 9, imagem 1 %32 Acer Spin 5 SP515-51GN-807G Hard Drive Replacement, Hard Drive: passo 9, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the three 3.8 mm screws from the hard drive brackets.
    • Unplug the hard drive cable.
    • Lift the hard drive out from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 33
Duração total: 1,330
