Ir para o conteúdo principal
Acer Spin 5 SP513-51-57TP Battery Replacement
O que você precisa
  1. Acer Spin 5 SP513-51-57TP Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Battery Replacement: passo 2, imagem 1 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Battery Replacement: passo 3, imagem 1 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 3, imagem 2 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Battery Replacement: passo 4, imagem 1 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 4, imagem 2 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 4, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Battery Replacement: passo 5, imagem 1 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 5, imagem 2 %32 Acer Spin 5 SP513-51-57TP Battery Replacement: passo 5, imagem 3 %32
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
Conclusão
Anthony Vansell
Membro desde: 01/24/20
872 Reputação
Autoria de 5 guias
Equipe
Hufflepuff Membro de Hufflepuff
Local Repair Groups
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 36
Duração total: 3,426
