Ir para o conteúdo principal
Acer Spin 5 N17W2 Screen Assembly Replacement
O que você precisa
  1. Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: passo 1, imagem 1 %32 Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: passo 1, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the six 6mm screws.
    • Use Phillips #1 screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 2, imagem 1 %32
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 3, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the three 5mm screws.
    • Use the Phillips #1 screwdriver to remove the three 5mm screws on another side of hinge.
  4. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 4, imagem 1 %32
    • Disconnect chips from the two end side of hinge.
  5. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to pry the hinge up.
  6. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 6, imagem 1 %32
    • Remove the wireless LAN chip from the motherboard.
  7. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 7, imagem 1 %32
    • Detach the sensors on each side of the hinge from the motherboard.
  8. Acer Spin 5 N17W2 Screen Assembly Replacement: passo 8, imagem 1 %32
    • Detach the screen assembly from the device.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 2,544
