Ir para o conteúdo principal
Acer Spin 5 N17W2 SSD Replacement
O que você precisa
  1. Acer Spin 5 N17W2 SSD Replacement, Battery: passo 1, imagem 1 %32 Acer Spin 5 N17W2 SSD Replacement, Battery: passo 1, imagem 2 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 SSD Replacement: passo 2, imagem 1 %32
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 SSD Replacement: passo 3, imagem 1 %32
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 SSD Replacement: passo 4, imagem 1 %32
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 SSD Replacement: passo 5, imagem 1 %32
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 SSD Replacement: passo 6, imagem 1 %32
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 SSD Replacement, SSD: passo 7, imagem 1 %32
    • Disconnect the SSD from the laptop.
    • At the time of guide creation, the device did not come equipped with the SSD.
Conclusão
2 comentários
That's not the RAM, that's the m.2 SSD slot. The RAM on this laptop is soldered to the mainboard and cannot be replaced/repaired.
Stephen Feger - Responder
Ok, so they changed this guide from a RAM change to an SSD change. Fine. One thing to point out is that the default m.2 drive for this laptop is a SATA based m.2, not a PCIe. Not sure if it can handle a PCIe m.2 drive.
Stephen Feger -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 32
Duração total: 1,806
