Ir para o conteúdo principal
Acer Spin 5 N17W2 Motherboard Replacement
O que você precisa
  1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: passo 1, imagem 1 %32 Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Motherboard Replacement: passo 2, imagem 1 %32
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Motherboard Replacement: passo 4, imagem 1 %32 Acer Spin 5 N17W2 Motherboard Replacement: passo 4, imagem 2 %32
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
  5. Acer Spin 5 N17W2 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove four 5 mm screws using the Phillips #1 screwdriver.
  6. Acer Spin 5 N17W2 Motherboard Replacement: passo 6, imagem 1 %32
    • Take off the black heat sink (be careful of the grey thermal grease).
  7. Acer Spin 5 N17W2 Motherboard Replacement: passo 7, imagem 1 %32 Acer Spin 5 N17W2 Motherboard Replacement: passo 7, imagem 2 %32 Acer Spin 5 N17W2 Motherboard Replacement: passo 7, imagem 3 %32
    • Remove all peripherals connecting to the motherboard.
    • Remove the second chip.
    • Remove the wireless LAN chip.
  8. Acer Spin 5 N17W2 Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the three connection wires.
  9. Acer Spin 5 N17W2 Motherboard Replacement: passo 9, imagem 1 %32 Acer Spin 5 N17W2 Motherboard Replacement: passo 9, imagem 2 %32
    • Take off the connecting port with black tape.
    • Take off the last port with purple tape.
  10. Acer Spin 5 N17W2 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the motherboard from the device.
Conclusão
2 comentários
I need the motherboard where I can buy it..
john fredy mendoza torres - Responder
I need the motherboard where I can buy it please...
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 1,410
