Ir para o conteúdo principal
Acer Spin 5 N17W2 Hard Drive Replacement
O que você precisa
  1. Acer Spin 5 N17W2 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Acer Spin 5 N17W2 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Hard Drive Replacement: passo 2, imagem 1 %32
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Hard Drive Replacement: passo 4, imagem 1 %32
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Hard Drive Replacement: passo 5, imagem 1 %32
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Disconnect the hard drive and remove it from the device.
    • At the time of guide creation, the hard drive was not included in the device.
Conclusão
2 comentários
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Peter Iliopoulos - Responder
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
Stephen Feger - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 2,980
