Introdução
A cooling fan consists of a rotating arrangement of vanes or blades which act on the air to blow away the heat to cool down the device. If your laptop is overheating or the system noticed you the cooling fan is not functioning properly, you might need to replace your cooling fan. This manual guide is helping you to fix the cooling fan!
O que você precisa
Use the Phillips #1 screwdriver to remove six 6 mm screws.
Use the same screwdriver to remove six 5mm screws.
