Introdução
This guide will show you how to replace your Acer Spin 3 SP315-51-757C fan and heat sink. Leaving your laptop on for long periods of time or leaving it in a hot room could lead to issues with your heatsink and fan. If your laptop has been overheating or having temperature problems then they may need to be replaced.
O que você precisa
Remove the two Phillips #0 screws holding the battery inside the laptop case.
Using a Phillips #0 screwdriver, remove the three screws that hold the fan on top of the motherboard.
