Ir para o conteúdo principal
Acer One 10 S1003-19GY Rear/Front Camera Replacement
O que você precisa
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: passo 1, imagem 1 %32 Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 2, imagem 1 %32
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: passo 3, imagem 1 %32
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 4, imagem 1 %32 Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 4, imagem 2 %32 Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 4, imagem 3 %32
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 5, imagem 1 %32
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 6, imagem 1 %32 Acer One 10 S1003-19GY Rear/Front Camera Replacement: passo 6, imagem 2 %32
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 359
