Ir para o conteúdo principal
Acer One 10 S1003-114M Track Pad Replacement
O que você precisa
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: passo 1, imagem 1 %32
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: passo 2, imagem 1 %32
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: passo 3, imagem 1 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 3, imagem 2 %32
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: passo 4, imagem 1 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 4, imagem 2 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 4, imagem 3 %32
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: passo 6, imagem 1 %32
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: passo 7, imagem 1 %32
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: passo 8, imagem 1 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 8, imagem 2 %32
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: passo 9, imagem 1 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 9, imagem 2 %32
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: passo 10, imagem 1 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 10, imagem 2 %32 Acer One 10 S1003-114M Track Pad Replacement: passo 10, imagem 3 %32
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: passo 11, imagem 1 %32
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: passo 12, imagem 1 %32
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: passo 13, imagem 1 %32
    • Gently remove the trackpad from the keyboard.
Conclusão
Karan Karthik
Membro desde: 04/01/19
217 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G6, Harley Spring 2019 Membro de IUPUI, Team S2-G6, Harley Spring 2019
IUPUI-HARLEY-S19S2G6
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 726
