Ir para o conteúdo principal
Acer One 10 S1003-114M Screen Hinge Replacement
O que você precisa
  1. Acer One 10 S1003-114M Screen Hinge Replacement, Screen Hinge: passo 1, imagem 1 %32
    • Open the screen.
  2. Acer One 10 S1003-114M Screen Hinge Replacement: passo 2, imagem 1 %32
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Screen Hinge Replacement: passo 3, imagem 1 %32 Acer One 10 S1003-114M Screen Hinge Replacement: passo 3, imagem 2 %32
    • Turn over the keyboard and use the plastic opening tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Screen Hinge Replacement: passo 4, imagem 1 %32 Acer One 10 S1003-114M Screen Hinge Replacement: passo 4, imagem 2 %32 Acer One 10 S1003-114M Screen Hinge Replacement: passo 4, imagem 3 %32
    • Remove the ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Screen Hinge Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Screen Hinge Replacement: passo 6, imagem 1 %32
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Screen Hinge Replacement: passo 7, imagem 1 %32 Acer One 10 S1003-114M Screen Hinge Replacement: passo 7, imagem 2 %32
    • Use a pair of tweezers to remove the electrical connector for the hinge. Pull gently while wiggling the connector back and forth.
    • Remove the adhesive tape holding the wire down.
  8. Acer One 10 S1003-114M Screen Hinge Replacement: passo 8, imagem 1 %32 Acer One 10 S1003-114M Screen Hinge Replacement: passo 8, imagem 2 %32
    • To free the hinge, remove the 4 mount screws with a Phillips #0 screwdriver.
  9. Acer One 10 S1003-114M Screen Hinge Replacement: passo 9, imagem 1 %32 Acer One 10 S1003-114M Screen Hinge Replacement: passo 9, imagem 2 %32
    • Remove the disconnected hinge from the keyboard.
Conclusão
6 outras pessoas executaram este guia.
Justin Bawinkel
Membro desde: 04/01/19
327 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G6, Harley Spring 2019 Membro de IUPUI, Team S2-G6, Harley Spring 2019
IUPUI-HARLEY-S19S2G6
Membros da 4
Autoria de 2 guias
5 comentários
Where can I buy the hinges of acer one 10 D16H1?
ladysam020889 - Responder
Do you know where I can find hinges of acer one s1003?
Al Monslisa - Responder
The hinge is so stiff it broke off the keyboard tabs. I need to loosen the hinge and replace the keyboard base, or hopefully just the positioning tabs (if they can be reglued).
PGI Cruiser - Responder
Tutoriel bien expliqué, merci pour tout, vous m’avez bien aidé à changer la charnière moi-même.
Francis Meylemans - Responder
Where can i buy new hinge for acer one s1003 , plss suggest me
Arvind - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 32
Duração total: 6,215
