Ir para o conteúdo principal
Acer One 10 S1003-114M Key Replacement
O que você precisa
  1. Acer One 10 S1003-114M Key Replacement, Key: passo 1, imagem 1 %32 Acer One 10 S1003-114M Key Replacement, Key: passo 1, imagem 2 %32
    • Make sure your device is powered off and disconnected from any power supply.
    • Open the laptop and disconnect the tablet screen from the magnetic keyboard dock by gently lifting the screen up.
    • Use tweezers to gently pry up the damaged key.
  2. Acer One 10 S1003-114M Key Replacement: passo 2, imagem 1 %32
    • White plastic springs may become misaligned when removing key.
    • If the plastic springs do become misaligned, use tweezers to realign springs by popping them back into their horizontal placement.
Conclusão
Um comentário
Is there any place we can buy replacement keys?
Nur Ahmad Furlong - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 3,088
