Introdução
Do you have a key that is broken or has worn markings? If so, use this guide to replace a key.
O que você precisa
Make sure your device is powered off and disconnected from any power supply.
Open the laptop and disconnect the tablet screen from the magnetic keyboard dock by gently lifting the screen up.
Use tweezers to gently pry up the damaged key.
Quase terminado!
Conclusão
