Ir para o conteúdo principal
Acer One 10 S1002 145-A Battery Replacement
O que você precisa
  1. Acer One 10 S1002 145-A Battery Replacement, Motherboard: passo 1, imagem 1 %32
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Battery Replacement: passo 2, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement: passo 2, imagem 2 %32
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Battery Replacement: passo 3, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement: passo 3, imagem 2 %32 Acer One 10 S1002 145-A Battery Replacement: passo 3, imagem 3 %32
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Battery Replacement: passo 4, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement: passo 4, imagem 2 %32
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Battery Replacement: passo 5, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement: passo 5, imagem 2 %32 Acer One 10 S1002 145-A Battery Replacement: passo 5, imagem 3 %32
  6. Acer One 10 S1002 145-A Battery Replacement: passo 6, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement: passo 6, imagem 2 %32
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Battery Replacement: passo 7, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement: passo 7, imagem 2 %32 Acer One 10 S1002 145-A Battery Replacement: passo 7, imagem 3 %32
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Battery Replacement: passo 8, imagem 1 %32
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Battery Replacement, Battery: passo 9, imagem 1 %32 Acer One 10 S1002 145-A Battery Replacement, Battery: passo 9, imagem 2 %32 Acer One 10 S1002 145-A Battery Replacement, Battery: passo 9, imagem 3 %32
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
Conclusão
20 outras pessoas executaram este guia.
Shannon Griffin
Membro desde: 10/03/16
1.372 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-3, Sullivan Fall 2016 Membro de USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
Membros da 4
Autoria de 5 guias
2 comentários
Thankyou for this information. I am replacing a battery on my own, and your tutorial is extremely clear and helpful.
shop_arod - Responder
I want a ..
Motherboard
4D Guru Channel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 75
Duração total: 18,825
