Ir para o conteúdo principal
Acer Nitro 5 AN517-51-56YW Touch Pad Replacement
O que você precisa
  1. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: passo 1, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: passo 1, imagem 2 %32 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: passo 2, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: passo 2, imagem 2 %32
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: passo 3, imagem 2 %32
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
  4. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: passo 4, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: passo 4, imagem 2 %32
    • Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
    • Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
    • Lift the adhesive ribbon to be able to remove the touchpad.
    • Do not remove the ribbon completely, only the part that is on the touchpad.
  5. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: passo 5, imagem 2 %32
    • Lift the touchpad towards you from the bottom.
Conclusão
Giovanni Lopez
Membro desde: 09/15/22
88 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 29
Duração total: 425
