Ir para o conteúdo principal
Acer Nitro 5 AN517-51-56YW Battery Replacement
O que você precisa
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: passo 1, imagem 2 %32 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: passo 2, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: passo 2, imagem 2 %32
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN517-51-56YW Battery Replacement: passo 3, imagem 2 %32
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
Conclusão
Jacob Elkins
Membro desde: 09/15/22
221 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 43
Duração total: 2,232
