Ir para o conteúdo principal
Acer Nitro 5 AN515-55-56GN HDD Replacement
O que você precisa
  1. Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: passo 1, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: passo 1, imagem 2 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: passo 1, imagem 3 %32
    • Turn off the laptop and unplug it from the charging cord.
    • Flip the laptop over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove ten 9 mm screws.
  2. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 2, imagem 2 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 2, imagem 3 %32
    • Use your fingers or an opening tool to remove the back case by separating it at the seam.
    • Work your way gently around the perimeter to undo the clips.
    • Remove the back case.
  3. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 3, imagem 2 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 3, imagem 3 %32
    • Unplug the battery cable from the connector attaching the battery to the motherboard.
    • Make sure that the laptop battery is unplugged or remove the battery before installing the HDD.
  4. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 4, imagem 2 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 4, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove four 3 mm screws from the hard drive bracket.
    • Remove the bracket from the device.
  5. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 5, imagem 2 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 5, imagem 3 %32
    • Place the HDD 1TB in the bracket.
    • Use the Phillips #0 screwdriver to secure the 2 mm screws that hold the HDD in the bracket.
    • The 2 mm screws are included with the new HDD.
  6. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 6, imagem 2 %32
    • Attach the SATA connector to the HDD.
  7. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 7, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 7, imagem 2 %32
    • Slide the HDD into the socket on the motherboard.
    • Replace the four 3 mm screws using the Phillips #0 screwdriver.
  8. Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 8, imagem 1 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 8, imagem 2 %32 Acer Nitro 5 AN515-55-56GN HDD Replacement: passo 8, imagem 3 %32
    • Slide the hard drive cable into the connector on the motherboard.
    • Flip the black lock down to secure the cable.
Conclusão
That is all step-to-step on how to Install the new HDD to the laptop Acer Nitro 5 (AN515-55-56GN)
5 outras pessoas executaram este guia.
Duy Nguyen
Membro desde: 09/16/21
253 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 50
Últimos 30 dias: 214
Duração total: 5,436
