Ir para o conteúdo principal
Acer Nitro 5 AN515-55-55M1 Motherboard Replacement
O que você precisa
  1. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 2, imagem 2 %32
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: passo 3, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: passo 3, imagem 2 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: passo 3, imagem 3 %32
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
  5. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Disconnect the seven cables from the motherboard using an iFixit opening tool.
  6. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 6, imagem 2 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 6, imagem 3 %32
    • Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
  7. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 7, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 7, imagem 2 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
    • Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
    • Lift the taped wires off of the fans on the right and left sides.
  8. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 8, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 8, imagem 2 %32 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: passo 8, imagem 3 %32
    • Lift up the right side of the motherboard.
    • The cables may need some guidance to leave the management holes on the motherboard.
    • Continue to lift at an angle until there is a give.
    • Remove the motherboard and fans from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Samuel Rouillard
Membro desde: 03/30/21
674 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-4, Mellen Spring 2022 Membro de UMass Dartmouth, Team 1-4, Mellen Spring 2022
UMASSD-MELLEN-S22S1G4
Membros da 3
Autoria de 5 guias
Um comentário
Where would I go to buy a new motherboard and display?
David Nguyen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 78
Últimos 30 dias: 200
Duração total: 5,516
