Ir para o conteúdo principal
Acer Nitro 5 AN515-55-55M1 Battery Replacement
O que você precisa
  1. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 2, imagem 2 %32
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: passo 3, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: passo 3, imagem 2 %32 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: passo 3, imagem 3 %32
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-55-55M1 Battery Replacement: passo 4, imagem 2 %32
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
Conclusão
Congratulations! You have successfully replaced the battery of your Acer Nitro 5 AN515-55-55M1!
Samuel Rouillard
Membro desde: 03/30/21
681 Reputação
Autoria de 5 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 220
Ao todo: 10,976
